Thread: Timer for pump
    Jun 2014
    NJ
    2
    Timer for pump
    I woudl like to install a timer for my pump but I'm not sure what i shoudl purchase.
    The details of the pump are:
    Manufacturer A.O. Smith
    1.5 HP (1.10 SF)
    Cat Part 7-184949-22
    Type CX
    Volts 230/115
    Amps 8.0/16.0
    RPM 3450
    I don't want to spend a fortune but want somethign that is reliable and will last a good few years.
    Any suggests would be very welcome
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Timer for pump
    Intermatic mechanical timers have dominated the market for years. They're pretty bombproof. All you need to know is if you are wired up 115 or 230 and will it get mounted inside a panel or need to be in its own weatherproof box. Then just pick the right model.
