Thread: CYA test
    May 2014
    Lakewood, NJ
    10
    CYA test
    Is there a way to use cya test so I dont use them up so fast? whats the cheapest way to get refills, i have all other test dont want to buy whole new kit just for cya test.
    21K Gal. In ground vinyl cartridge filter heater
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Re: CYA test
    Quote Originally Posted by tenpool View Post
    You can buy just the reagent from Duraleigh ... i think it was around $10
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: CYA test
    http://tftestkits.net/TF-100-Refills-c11/
    You can get the little bottles for the K-2006 or the big TF100 bottle. Same stuff. Might as well check your FAS-DPD powder and all that too and save shipping.
    May 2014
    Lakewood, NJ
    10
    Re: CYA test
    thanks
    Nov 2011
    Albany, NY
    496
    Re: CYA test
    thanks
    And don't forget that once you have your CYA added you don't need to test it again unless you add a ton of water or get deluged by rain .... it typically doesn't change much.
    Haywood Sand Filter
    Vinyl Liner
