Results 1 to 11 of 11
Thread: Balanced, now water feels "different"
    May 2014
    Houston
    24
    Everything seems to be holding steady, here in Houston its hot, having to add acid every couple of days.
    FC=6.5
    CC=0
    CH=275
    TA=80
    CYA=50
    pH=7.4
    Current concern is that the water feels different than before I added CYA, raised FC and lowered pH. Its "rougher" feeling on our skin, more dried out feeling. Also fingers get "pruney" not sure if I noticed that before, or took much longer. Is this caused by the CYA, higher FC, or lower pH? Would adding borates solve this?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Balanced, now water feels "different"
    Have to be honest, that's the first time I've heard somebody describe their water that way. The "pruney" fingers I can also get if I'm in the water for an extended time. Otherwise I have no explanation of the roughness. The addition of borates to aid in the feel of the water will not always be noticed. I've read some people feel no difference.
    Somebody else may have an idea and chime in.
    If you could add all your pool and equipment info to your sig it will help us help you better. Thanks. 😎
    Jeff
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    That is indeed strange. I have borates added to my pool for a number of reasons. It's a good pH buffer, and can help slow down the start of an algae bloom IF I ever accidentally let my CL level drop too low for a short period of time. My daughter has eczema, and the addition of borates does help her skin condition. We can't let her swim at all in public pools. I know borax isn't the entire reason for the better water, but I do feel it improves the feel.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    May 2014
    Houston
    24
    See more details in the sig,
    For what I know it is a little strange, the water felt more natural uncorrected. When i bought the house 2 months ago the numbers were
    pH=8.2+
    FC=1
    CC=.5
    TC=1.5
    CH=300
    TA=240
    CYA=0
    Felt great at that time, I only lowered the pH and added enough CYA to help stabilize my chlorine.
    15k Gallon saltwater Pebbletec, Jandy Stealth, Cartridge filters, Hayward Aquarite T-15 SWG, Hayward heater, TF100
    It's probably the salt.
    18' x 36' saltwater inground vinyl pool
    May 2014
    Houston
    24
    Well when i first got the pool it was at 2600 ppm..I threw in 3 or 4 bags and got it to 3400..now its about 3300 or so the readout says.
    Jun 2012
    Louisville, KY
    266
    It's probably the pH. You're a little out of the recommended range of 7.5-7.8. I can always tell when my pH is a little off when I open my eyes underwater, if it's 7.6-7.7 then no burning.
    At 8.2+ your water was more basic (as opposed to acidic) which may have "felt" better on your skin and felt more slippery/slick. You can add some borax to bump it up a little to get in range or monitor to see if pH naturally rises. My pool fortunately hits a happy spot of 7.6 and just sits there all season long.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    My PH last year was rock steady at 7.2-7.4 with no eye irritation or water not feeling right. Everybody is different though. 😎
    Jeff
    May 2014
    Houston
    24
    Can you physically feel the difference between 2500 ppm vs 3000 vs 3500ppm?
    Jun 2012
    Louisville, KY
    266
    Doubt it. If anything salt feels better.
    Jun 2014
    860
    Pizza dough talk was moved to the Coffee Bar. CH and its effect on Pizza Dough... Zea3
    I think this very subjective but I always feel like my skin is a lot dryer and "crusty" when I swim in high CH water. I grew up in the NY where there's very little Ca in the water, the water is more acidic and usually has a good amount of iron in it (and it's the only water that can make good pizza dough, but that's a topic for a different TFP thread). That water always feels better on my skin. I now live in the SW where we can't get CH below 280ppm unless you have a solid water softner.
    So my vote is for CH as the problem.
    Last edited by zea3; 07-16-2014 at 11:17 AM. Reason: move off topic posts to coffee bar
