Thread: Pump too powerful for manaul vacuum-Don't know what else to
    hayward power-Flo Matrix Pump serier
    Above ground doughboy 16x24-dug 2 feet in the ground
    Returned Robo-Kleen cause that stopped working after 1 or 2 times.
    Purchased good ole manual vacuum. Followed all the steps.
    Hose from Skimmer to Pump collapsed upon vacuuming.
    Thought...ok hose not strong enough to take suction pressure.
    Went to 2 Home Depot's, 1 Lowes, 2 pool stores, no luck.
    Finally found 1 1/2 inch clear braided flexi hose. Looks strong as could be.
    In the rain (NY), went out to switch the hoses. Ok....a little wet, but that's ok cause this is going to work. Put all in place, and......same thing happened.
    We're at our witts end. My husband is thinking about building a hose of pvc with elbows, etc. cause that can not collapse!
    Kindly share your experience and fixes. This was supposed to be FUN!
    Also...... Hayward Pro Series High Rate Sand Filtration sytem blast sand for 1 or 2 seconds into the pool each time the filter is turned on.
    Please help us!
    Thank you in advance
    Vaughan Williams
    Octopus Pools
    Kyrenia
    Northern Cyprus
    Pool construction, repairs & maintenance.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Pump too powerful for manaul vacuum-Don't know what else to
    Only thing I can suggest is to try connecting the vac. hose to the skimmer without the vac. head attached and see if it still collapses. If it doesn't, then you need to find a more free flowing vacuum. If it does, then I don't know what to do. How can you move the vacuum around the pool if it has hard plumbing?
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    First, make sure you don't have a restriction in hose or vac that is reducing water flow. If that's not the problem, you need to let some water flow into the skimmer directly without passing through the hose. I'd buy a spare vacuum plate adapter and start drilling 1 inch holes in it until you get to a reasonable flow through the vacuum.
    Mar 2008
    Los Angeles, Ca
    222
    Hi
    I had a problem, my suction was too strong, so I could not move the vac head, so my problem was not quite as bad.
    I drilled some holes in the ends of my vac hose. This fixed my problem.
    For your problem, you would need the holes in the skimmer end.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Dec 2007
    Central New York
    504
    Quote Originally Posted by mriche
    Alot of people have done that without any problems. Just remember to put a couple of unions in the line, close to each end. Have you tried PVC Flex Pipe?
    I would still first check the vacuum hose real good for a blockage.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
