Results 1 to 8 of 8
Thread: First water test by myself
    Jul 2014
    Dallas, Tx
    20
    Howdy, guys.
    Got my TF100 this aftertoon, and cannot wait for 1 sec but did first time ever water test.
    07/14/2014 06:30PM
    FC: 1.5
    CC: 0.5
    CYA: 30
    TA: 100
    pH: 7.8~8.0
    CH: 400 ppm
    It seems everything looks good except for pH and CYA. I would add another 1qt muranic acid tomorrow morning before work to lower pH first. but I do have a question for CYA adjustment.
    I bought 4lb hth conditioner and stabilizer from walmart, but I'm not quite sure if I should wait for a couple of hours after adding murianic acid tomorrow morning, or I could just pull conditioner into a socket and hanging on skimmer. Please give some advice, thank you.
    32 ft x 25 ft x (4.5 ft ~ 8.0 ft) 30k gallon pool || AquaPure Model APUREM SWG || Pentair MiniMaxPlus Electronic Ignition Heater || Pentair FNS Plus 60 D.E Filter || TFTestKits TF-100
    PoolMathCalc
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: First water test by myself
    No need to wait. The muriatic acid's going in the water in front of a return. The CYA sock is in the skimmer.
    Jul 2014
    Dallas, Tx
    20
    Got it. Much appreciate it, man.
    PoolMathCalc
    Jun 2014
    Boca Raton, FL
    101
    FC 1.5 is a little low, especially if you are raising CYA. I would get FC up to 4 or 5 to prevent algae from getting a start.
    16x32 DiamondBrite kidney, 12,500 gal. (circa 1985) 3/4hp Hayward SII, Harmsco BF84, Taylor K-2006, Hayward SwimPure Plus / Tcell-15
    Boca Roton, Fl. USA.
    prior 17k gal. vinyl, Sand filter
    Jul 2014
    Dallas, Tx
    20
    Quote Originally Posted by DogsHouse_MyPool View Post
    Thanks for advice. So, you suggested that I should hold CYA adjustment, but pull more bleach to raise FC first, do I understand you correctly?
    If I understand correctly, conditioner and stabilizer would dissolve slowly, since I have to work and out of house tomorrow day time, can I start put conditioner sock in the skimmer, and pull bleach later after I come back from work?
    PoolMathCalc
    Mar 2014
    Las Vegas
    288
    You can do both bleach and CYA at the same time. No need to wait.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    496
    Keep in mind the CYA test should be done in bright sunlight. If you do it at 6:30 it may be a different result than in the middle of the afternoon when the sun is at its' brightest. I am not sure but it may make a difference??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    May 2014
    Lewisberry, PA
    93
    Don't forget that it might take up to a week or more for the conditioner you put in the sock to show up on your CYA test. So assume for testing purposes that what you targeted for your CYA is already there.
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
