Thread: First Pool Excitement - Virginia Beach, VA
    Jul 2014
    Virginia Beach, VA
    4
    Our install started today with the initial dig. The pool is a Viking Fiberglass Venice model (40'x16' w/ 8 1/2' deep end). Here are some shots (my photo skills are very basic) . . .
    Here you can see most of the backyard with the pool layout prepped (faint blue lines) and marked. The tree inside the pool boundary was moved to a far corner of the yard. You can see the back of a church in the background. The pastor is very nice and offered to let us access our yard through theirs, as long as we fixed any tracks which get made. This will help later when the pool shell comes in as the truck can back right up to the hole. I have to admit, it would have been kind of neat to see it craned over the house . . .
    The excavation begins. Virginia Beach is notorious for groundwater, and we hit it! They also discovered some very, very old underground pipes cutting through the yard which were not on any survey or plot maps. These were hexagonal shaped and made of a red clay/terracotta. You can see a grayish area on the far side of the pool where they existed.
    Here you can see the progress on the dig.
    About 5 minutes after the previous picture was taken, the far end wall sloughed off. The excavator had to pull away quickly, and unfortunately drove across a couple feet of my neighbors yard.
    May 2014
    The Woodlands, TX
    48
    Re: First Pool Excitement - Virginia Beach, VA
    Well it could have ended much worse. Are they going to have to do a gunite flash or something to stabilize the walls before they keep going?
    [Under Construction] ~22.4k Gallons - 35x18 freeform IG Gunite w/ 6" raised freeform spa - Pentair Clean and Clear 420, Intelliflo 3.2VF, 320cl, Master Temp heater, Easy Touch 4/Screenlogic, Maytronics M4
    Decking and plaster still undetermined. - Contract Signed 5/10/14 - Excavation 5/23/14 - Steel 5/24/14 - Stub Out 5/24/14 - Gunite 5/30/14 - Plumbing 6/3-6/4/14 - Electrical 6/5/14
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Watching this one! I'm in Va Beach too. Welcome to TFP.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2014
    Virginia Beach, VA
    4
    Too much rain the night before the pool arrived, meant it had to be craned in to position. The ground was too wet and soft for the truck to deliver through the backyard, so . . . .
    We heard the escort sirens before we saw the truck. When they finally got in to our subdivision, it started to get exciting . . .
    . . . yes, my heart was in my throat through the entire lift . . .
    . . . but everything fit well . . .
    . . . and now we on to the final stages . . .
    Casey's Avatar
    SW PA
    10,428
    That's a really nice pool!
