Thread: CYA and solar cover
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    CYA and solar cover
    I have a solar cover that is put on the pool every night. All week the solar cover stays on the pool until around 3pm when I get home from work. If it works the way "they" say it does it should protect the chlorine from the sun. If this logic is true, would it be safe to assume that I can maintain CYA on the low side to have to use less chlorine? Just wondering
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Re: CYA and solar cover
    You can use mildly lower CYA levels when the pool is covered nearly all the time, but there isn't any real reason to do so. And you don't want to let CYA get too low or that one day you leave the cover off will use up all the chlorine.
