Results 1 to 7 of 7
Thread: New motor but lower pressure
    May 2009
    Greenwood, Indiana
    25
    I had to replace my pump motor this past weekend. The old motor was 1 HP with a 1.4 safety factor. The new motor, although from a different manufacturer, has the same specs, 1 HP with a 1.4 safety factor. My concern is that the old motor would show 15 PSI on the filter pressure gauge. The new motor only shows 9 PSI. I've confirmed with two different pressure gauges.
    Is there something I'm missing? Am I concerned about something that doesn't really matter?
    Strom
    16 x 32 Inground Vinyl, Infinity 2000 Automatic Cover
    Hayward S210T 2.2 sq ft Sand Filter with 1 HP Speck Badu EcoM3V Pump, Hayward H200 Heater
    Dolphin DX4 w/remote, CircuPool RJ-30 SWG, Taylor K-2006, SpeedStir, Borates, Zeosand
    Re: New motor but lower pressure
    That is very strange. It may or may not be a problem, but it is worth looking into further.
    Do you see any air in the pump strainer basket?
    Could there be a valve somewhere on the suction side of the pump that got moved so the flow into the pump is restricted compared to what it was before?
    May 2009
    Greenwood, Indiana
    25
    Thanks for the reply Jason.
    There are no bubbles in the strainer. I also confirmed that the main drain and skimmer suction valves are open 100%. I'll borrow a clamp on amp meter from work and confirm the motor is pulling nameplate amps.
    Strom
    Jul 2011
    Perrysburg, OH
    88
    Did you change the seal and check the impeller when you had it apart?
    May 2009
    Greenwood, Indiana
    25
    New seal installed and checked impeller. I was happily surprised by the lack of hair in the impeller. (Wife and two daughters with long black hair.)
    Strom
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Are both motors rated for the same number of rpms?
    May 2009
    Greenwood, Indiana
    25
    Problem is solved and turned out to be a case of pilot error. The motor is dual voltage rated for 230 or 115 volt operation. It is shipped to run on 230. I read but misunderstood the instructions on how to set the motor up for 115 volt operation. The reason the pressure read low was due to supplying 115 volts to a 230 volt motor. Once the internal motor wiring was corrected, everything was back to normal.
    Strom
