Results 1 to 7 of 7
Thread: New Aquapure 1400
    Jul 2013
    Clarksburg, MD
    93
    New Aquapure 1400
    Just turned on today, everything seems straight forward except one thing PB stated, he said to shock the pool every 2 weeks.....he said to do this with the Aquapure (has a button to slam) and it runs at 100% for 24 hours.
    Read pool school and quickly searched forum and didn't see anything on this. I'm guessing I don't need to do this but just checking.
    Thanks
    18k gallon IG Sunstone Pearl pebble finish pool, Jandy Aquapure 1400 SWG, Jandy 1.5HP VS E-Pump, Jandy 60sqft DE filter, Jandy Legacy Propane Heater, Polaris 3900 Robotic Cleaner, TF-100 w/ SpeedStir, Anchor Mesh pool cover
    Re: New Aquapure 1400
    No, there is no reason to do that. You want to SLAM the pool when you are having a problem, for example get algae, but otherwise just maintain the recommended levels and you should be fine.
    Jul 2013
    Clarksburg, MD
    93
    That's what I thought. Thanks
    May 2014
    Mesa, Arizona
    180
    Quote Originally Posted by Omnipotent View Post
    Thanks
    He may be talking about "boost" which when you press the button the cell goes to 100% for 24 hours or until turned off. But then again, in the manual it says to shock the pool every other week. So which is true?(don't ever leave cell on when adding chemicals, shut it off). Don't need to do either. That manual was written quite a while ago and things have changed in the pool world. Stick around and read till your eyes hurt, then read some more. Lots of good stuff on these pages for one to decipher the correct way to get it done. Small pool? Big pool? It doesn't matter, this site does them all.
    Dialing in your new Aquapure 1400 will take some time. Mine has taken me a month and a half but I use a week's worth of tests between tweaking. Do it right and you will be able to sell the shock back to the pool stores as it will not be necessary. Get your ducks in a row with your chemicals...TA should be 70-90; try to keep PH in the range of 7.4-7.8; CYA keep from 60-80; FC right around 5 ppm; CH low 300's, maybe 325 like mine; Salt between 3,000-3500, 3,400 is ideal. Follow this and your Saturation Index should fall in the balance range of -0.20 or less.
    I'm running my new cell at 60% right now and I'm still producing more chlorine than I need nor want, 8 ppm. Next comes pump time, going to start with an hour less and then check chemicals to see what's going on. I feel that this will be the deciding factor. Wife wants me to do an hour less and I want to go 45 minutes less. We all know how this is going to turn out so I guess I'll keep you from the suspense and just do the hour.
    Keep your chemicals balanced (especially your PH) and your pumps and cell will run longer and will require less maintenance.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    May 2012
    Toronto, ON
    463
    I am having trouble with my Aquapure 1400 this year but in previous years I got the salt and CYA levels right a week or two after opening my pool and then didn't or need to add any chemicals all year. Maybe this is not recommended here but it was totally easy and essentially maintenance free. I would check chlorine occasionally win test strips but assuming that the SWCG was working all was good.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Jul 2013
    Clarksburg, MD
    93
    I was talking about the boost button, but I don't plan on using it unless something really goes south. So far everything is good, but now time to dial in run time vs rpm on pump (VS) so little tweaks until it's going well.
    Jun 2011
    Long Beach, CA
    2,781
    The rpm on the pump should not matter as long as it is high enough to provide enough flow for the SWG to operate. Having a high flow as compared to a low flow does not effect how much chlorine is produced. What matters is the pump on time and the SWG output %. The Aquapure does have a higher flow requirement than some of the other SWGs so make sure you are providing it enough flow.
