Thread: new pool pump issues
    Jul 2014
    Zephyrhills
    1
    Hello, Just had a new above ground pool set up. We have a carefree sand filter. My problem is that there is no label on the top of my pump and I am not sure if it is in the correct position for filtering my pool. Its been 5 days and I have had the water tested several times and added the chemicals required. We are using chlorine and have well water when we filled it. I am just not sure if its filtering correctly as I can't get it clear. Are there any sites to get a diagram where the pump should be pointing?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: new pool pump issues
    Welcome to the forum. If your pool has water coming back into it from the return line off the filter, your pump is hooked to the filter correctly. Please post a full set of test results and how they were obtained.
