Thread: Can't remove filter housing top.
    Jennica's Avatar
    May 2012
    NJ
    91
    Hi, everyone! I put a new O-ring on my filter top this year and the suction is so great that I can't get the top off. Any suggestions? I have the pressure released and the drain open.
    15' Round Above Ground 5,300 gallons
    Cartridge filter
    Taylor 2006 Test Kit
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    Re: Can't remove filter housing top.
    I've heard a pool professional recommend to turn the pump on for a second. Obviously, the belt that holds the top housing to the bottom needs to be removed. Make sure to let all of the air out through the pressure release on the filter, otherwise the top housing could jump off and hit you (it's not likely, though).
    Before doing this, take the lid off of your pump basket to relieve more pressure, and see if the top housing of the filter will come off then.
    Bobby (my pool)
    18,000 gallon in ground/white plaster
    Flotec pump/Aquatech MYB100 single cartridge filter - runs 6 hours/day in evening during summer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    After the filter is drained more or less, close it all up except the clamp and turn the pump on for a second or two. As the pump primes, it will build air pressure in the filter and pop the lid loose. Then kill it before you get water everywhere. It only takes a second, so stand by the switch. I do that every time so I don't end up with fiberglass itches.
    Jennica's Avatar
    May 2012
    NJ
    91
    Popped right off and I didn't lose an eye or anything.
    Thanks, guys!
    Are there any tricks for getting it back on easily? It usually takes me the longest time to line it up and create suction.
    Cartridge filter
    ThinkPad's Avatar
    Jul 2014
    East Coast
    227
    I also have a little trouble getting mine on. It's best to use some kind of lubrication on that o-ring so it will stay nice and firm! Otherwise it will slowly expand and cause leaks like mine!
    Bobby (my pool)
