Thread: Water turns brown when I add chlorine.
    Jul 2014
    Croghan
    1
    We set our pool up, fill it up with water from our well which we use in our house and to drink. Things look good until we add chlorine. Within hours of adding chlorine the water turns a rusty brown. Some suggested we use MetalOut before adding chlorine. That didn't help. What can we do to fix this and why is it happening?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Water turns brown when I add chlorine.
    Welcome to TFP!
    It's almost certainly iron being oxidized by the chlorine.
    Getting water from another source is the best option by far. Even pumping it from a pond or stream is better in the long run than dealing with that much iron.
    Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective. ProTeam's Metal Magic and Jack's Magic The Pink Stuff (regular), The Blue Stuff (fresh plaster), and The Purple Stuff (salt) are some of the top sequestrants. You can also find many other brands with similar active ingredients, some of which are noticeably less expensive.
    It will need to be added frequently as it breaks down over time.
