Thread: Does adding DE help clear that cloudiness
    Jul 2014
    BH (Saratoga Area), NY
    62
    Does adding DE help clear that cloudiness that many of us are experienceing towards the end of our SLAM. Everything else is going according to plan regarding CC and OCLT
    Upstate, NY, Direct Sunlight, Above Ground (18'x 33' x 4'), Oval 15700 gallons, Vinyl; Hayward S180T sand filter; 1 HP motor; TF-100
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Adding DE to Sand Filter
    Quote Originally Posted by Eddy24 View Post
    Not sure which "adding DE to sand" thread to bump...
    You really shouldn't bump someone else's thread with your question. Keep your questions about your pool in your thread. It really makes it a lot easier for someone to follow your progress.
    Topic split. JasonLion
    Now, in answer to your question, yes near the end of a SLAM this can help clear the water. Reading through the posts of yours I could find quickly I see you got your test kit around the 10th, but really didn't see anything about conducting a SLAM. How are your numbers?
    Support the site
    Jul 2014
    62
    Quote Originally Posted by tim5055 View Post
    I'll update my post and move the question over, thanks. I'm used to other forums wanting to condense threads instead of having the same topics over and over, my bad.
    May 2014
    Franklin, NC
    9,184
    Not bad, just a learning curve. Many other forums are topic oriented, while this one deals with many specific pools. It's easier for everyone if all of the information for your pool is kept together so people making suggestions have a history of what you have done.
    Support the site
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Does adding DE help clear that cloudiness
    I do find that adding a little DE (I use synthetic variety) to my Sand Filter does help filter out that last bit of cloudiness.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
