Thread: My above ground pool has little to no suction What is wrong?
    Jul 2014
    Jackson NJ
    1
    I was vacuuming leaves yesterday and noticed it was very difficult to get the leaves off the bottom of the pool. I checked the suction and there was little to no suction. What can I do? Do I need a new pump? My current pump is maybe 2-3 years old. Any help would be appreciated. Thanks
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    Re: My above ground pool has little to no suction What is wrong?
    Welcome to the forum. If you would add a signature line to your profile detailing your pool and equipment, we might can help.
    Apr 2014
    New Braunfels TEXAS
    1
    Check to make sure that there are no leaves clogging the intake on the pump, and make sure your filter is clean.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    There are a bunch of reasons why you have no suction:
    1. pump doesnt work.
    2. Filter is clogged.
    3. hose is filled with debris.
    4. the fitting that passes through the pool liner is plugged. (They usually have some kind of grid to stop big stuff from getting to your pump)
    5. Your vacuum head is plugged.
    Simple enough right. Just start knocking out the possibilities until you find the problem.
    I always use the leaf rake and get the big stuff before I put the vacuum to work. Leaf rakes are awesome tools. They are almost as handy as my SpeedStir.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
