Results 1 to 7 of 7
Thread: LED Light Recommendations
    Jul 2014
    lancaster, pa
    61
    Have a Pentair 120v pool light replacing them with an LED light any recommendations. Thinking about pentair intellibrite or hayward color logic 4.0 LED sp0527sLED
    pool owner 25yrs 25,000 gal plaster inground pool equip: pentair clean & clear Plus CCP42 cartridge filter,pentair whisperflow 1.5H pump, raypak heater r406a ng, trident uv s2-23, polaris 9550 sport pool cleaner
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: LED Light Recommendations
    I can say I've been happy with my pentair 5G LED.
    Just know that if you change to one of these, the wire is part of the new light. So you'll be pulling wire.
    I do believe there are retrofits that basically give you an LED light bulb that plugs into your existing fixture.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Ukie's Avatar
    May 2012
    Export, PA
    83
    I have two pentair intellibrites and love them despite having lights replaced under warranty.
    Not sure how they will hold up moving forward, we shall see.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I have FiberStars. Not familiar with those products, but I wish my lights could remember which color I last set them to. I would demand that feature if I were to ever purchase led pool lights again.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Quote Originally Posted by Ukie View Post
    I also like the pentair intellibrites, and the extra features I get when they installed with pentair automation. I do have one question for you... What issues requires replacement? Sometimes my lights take a long time to fire up when I turn them on.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jul 2014
    lancaster, pa
    61
    They are 20 plus years old and seals leak after replacement, light has water in it, fuse flips. I wanted to replace old with new LED and replace entire unit back up to the j box.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Quote Originally Posted by Killer95Stang View Post
    First led light lost brightness, and second one lost blue color. Both lights got fogged lens, however I'm not sure if it's direct failure cause.
