Thread: Try to raise TA and CYA, need some advice regarding the order of adding chemicals
    Jul 2014
    Dallas, Tx
    20
    based on pool store test(i ordered TF100, but I haven't had it yet),
    TA: 50ppm
    CYA: 30ppm
    pH: 8.0
    since adding baking soda would raise pH, i wonder if my order of adding chemical is the best way.
    1. adding acid first to drop pH to 7.2~7.4
    2. adding baking soda after pH tests
    As to CYA, i just bought 4lb conditioner/stabilizer from Walmart. I plan to pull some conditioner into a sock, then hanging on skimmer. But I m not sure if i should do that after pH lower or doesn't mater.
    THhnk you so much
    32 ft x 25 ft x (4.5 ft ~ 8.0 ft) 30k gallon pool || AquaPure Model APUREM SWG || Pentair MiniMaxPlus Electronic Ignition Heater || Pentair FNS Plus 60 D.E Filter || TFTestKits TF-100
    PoolMathCalc
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Try to raise TA and CYA, need some advice regarding the order of adding chemicals
    Right now I would add muratic acid to get the pH down a little and wait for the test kit.
    Don't add CYA until YOU confirm it is needed with your test kit. This is the test that pool stores mess up the most. They were telling me mine was 90 when it was 200+
    Keep testing and adding chlorine (liquid) as needed until the kit arrives.
    Support the site
    Smykowski's Avatar
    Sep 2011
    3,065
    Baking soda will have a very small effect on pH.
    However, I'm with Tim. Don't do anything until you get the kit and have results you can trust.
    Jul 2014
    Dallas, Tx
    20
    Quote Originally Posted by tim5055 View Post
    Quote Originally Posted by Smykowski View Post
    Thank you guys.
    I added 1qt muratic acid this morning before work. And, i believe my test kit would arrive either tonight or tomorrow.I will perform my first test tonight(excited) and see how it goes.
    PoolMathCalc
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by TxE4GL3k View Post
    Thank you guys.
    Great!! Waiting for results.
    Support the site
