Thread: AQUA RITE SWG Gone Crazy
    Jul 2014
    Raleigh, NC
    59
    A few weeks ago I installed a AQUA RITE SWG and have added the correct amount of salt to pool. My problem is that I am trying to adjust the percent output and I am having trouble. I started out at 50% for about a week and I could not get the chlorine above 1. I tried to super chlorinate and it made no difference. I decided to shock the pool with Cal Hypo and the chlorine went to 10 and now I am having trouble getting the chlorine down. I have turned the percent down to 60% and the chlorine is still at 8. It is almost like the SWG didn't really start working until I shocked the pool and now I can't get the chlorine down. Should I continue to reduce the % or do I need to do something else.
    The pool is a 32,000 gallon plaster surface.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: AQUA RITE SWG Gone Crazy
    You had algae or some other organics in the water that the SWG could not get ahead of. You were lucky that your single dose of shock (instead of a true SLAM) fixed it. Now the FC demand is back to normal the SWG is producing more than is consumed. Slowly lower percentage and/or run time until hit your target FC.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    487
    sorry to disagree but i would suggest turn off swg for one day or reduce to near zero for one day only
    then back to where you have it
    if you keep reducing the percentage you will overshoot and end up yoyoing
    i do agree you most likely had low level algae in the first place
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
