Thread: broken polaris port on pool wall
    Jul 2014
    Babylon NY
    2
    My 15 year old steel wall vinyl liner pool has a port on the wall for connecting the polaris 380. There are two nubs inside the fitting to assist in removing the fitting. If you insert the plastic tool that I purchased at Leslies, it catches the 2 nubs and enables the unscewing of tge fitting.
    Last winter when I closed the pool and attempted to remove the fitting the nubs broke off.
    I have tried multiple methods to remove the fitting, which seems securely in pkace. The 1/4 inch or so of the fitting outer edge is now breaking off.
    Surrounding the fitting is a collar with 4 phillips screws. I have been reluctant to remove the screws because I suspect the collar is holding the liner in place. If I remove it, the liner will stretch and I will have a big issue on my hands.
    I am out of ideas. Any suggestions how I might get the fitting out?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: broken polaris port on pool wall
    Internal pipe wrench would be my thought.
    Jul 2014
    Babylon NY
    2
    John
    Thanks for the suggestion. I'd never heard of an Internal pipe wrench. Will pick one up tomorrow after work and give it a try, and then post again. Many thanks for the suggestion.
    B
