Thread: TA effect on pH
    apoteker's Avatar
    Jun 2014
    Greenwood, IN
    8
    TA effect on pH
    I have a 31500 gallon vinyl liner pool and it seems as if I have to constantly add acid daily to keep my pH at around 7.5. My TA has been running at between 80 and 90. Here are my test results from this evening:
    FC 5.0
    CC 0.5
    pH 7.8
    TA 80
    CYA 35
    Is 80 an acceptable TA for my pool or should I attempt to raise it? Also, is it normal to have to adjust pH on a daily basis? Thanks in advance for replies!
    Re: TA effect on pH
    If your PH is constantly going up, you should let TA god down to 60. Higher TA levels mean more PH drift. Second, don't try to keep PH down at 7.5. Maintain PH closer to 7.7 to 7.8. Lower PH levels mean more PH drift.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Re: TA effect on pH
    80 TA is fine.
    Do you have hard water where you live? A lot of evaporation or splashout?
    Daily acid seems extreme once the TA gets down to double digits, unless you're constantly adding more TA via refills.
    apoteker's Avatar
    Jun 2014
    Greenwood, IN
    8
    Re: TA effect on pH
    No, my CA was 60 during my last test and I only have to add water about once per week. So I should let my pH stay higher than 7.5? I've tried to keep it around the middle of the suggested target levels.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TA effect on pH
    Do you have a SWCG?
    apoteker's Avatar
    Jun 2014
    Greenwood, IN
    8
    Re: TA effect on pH
    No SWG. I just add 12.5% liquid chlorine as needed.
    Quote Originally Posted by JohnT View Post
    Do you have a SWCG?
