Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Pool by the numbers (leveling out the levels) :-)
    May 2014
    Nevada, TX
    238
    Ok so if you happen to see my build thread you will know that we had about a week and a half with no filter. I didn't do much to work on the pools levels during that time. We got the filter installed on Friday and since then I have been paying particular attention to the pool. The sides of the wall and the floor have become quite slippery and filming. I.e. signs of algae growth! I check the free chlorine level and of course I had not. I had put some CYA in the pool but only about 4 pounds so not quite enough. I have since added about another 2 1/2 pounds of CYA and added another gallon of bleach. Today here are my test results
    FC: 1
    Ph: 7.2
    TA: 100
    CYA: 30
    Keep in mind I did add CYA yesterday morning to the pool. I put it in a pantyhose and stood in front of the return squeezing it out into the pool as it dissolved I was able to dissolve all of it within a couple of hours. While it was dissolved into the pool, I'm not sure if any of what I put in there yesterday is currently showing up in my test results. I did go ahead and buy a case of super shock today just in case I needed it. Thoughts comments suggestions would all be greatly appreciated?
    Steve
    Ps I don't normally consider myself dense but I am really struggling with understanding how to use the pool math.
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Pool by the numbers (leveling out the levels) :-)
    If it's slimy and CYA is 30, you need to add bleach or liquid shock to get to at least 12 FC. That is shock level.
    Assuming the pool is 27' diameter and 54" tall and filled to 48", your volume is 17100 gallons. 6 lbs of stabilizer will get you to about 46, which will make shock level 18 FC!
    What is Super shock? If it's a powdered or granular form of chlorine, it's going to add either Calcium or CYA with the chlorine. You don't want any more CYA and you didn't post CH readings, so I don't know if you can use it or not.
    Have you read the How-to article about poolmath?
    May 2014
    Nevada, TX
    238
    The shock is hth super shock sold at Walmart. I don't want to use it unless it's absolutely necessary.
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,023
    That's Cal-hypo. It won't mess with your CYA or pH. But you need to test the CH of your water. If it's low enough, that stuff is fine to use. But if it's high, you run the risk of scaling. What is your Calcium Hardness?
    May 2014
    Nevada, TX
    238
    Also I have read the how to and I'm still having some issues. Lol I will get it...I'm just slow. Lol
    Testing now! Give me a minute and I'll post results. THANK you Richard!!!
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    CH is 150
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,023
    Quote Originally Posted by starsfan33 View Post
    CH is 150
    You can use it. I assume a case is a twelve-pack? Twelve pounds will raise the CH by about 31, so it's okay. But when it's gone, don't use any more. And don't use it all at once! It's instant bleach - just add water.
    3.25 lbs of that stuff will take your FC to 12. When you use poolmath, use the dropdown menu to select Cal-hypo 53% on the second line of the FC box to get how much you need to use each time. Dissolve it in a bucket before pouring it in, lest it settle on the floor and leave white freckles.
    May 2014
    Nevada, TX
    238
    It's 10 1lb packets. I'll plug that into pool math and see what I can figure out!
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Richard as you stated pool math tells me that I need to use 3 pounds. I.e. three packs of this shock. However you said don't add it all at once. Did you mean not at all 10 bags at once or not to add all 3 pounds at one? I would assume that I actually need 3 pounds. But after my first mistake pouring bleach directly into the pool and not knowing that I needed to brush it around and not having a brush I don't want to make the same mistake. LOL so I want to make sure that I ask questions even if they seem redundant or ridiculous. So what I am understanding is that I need to take a 5 pound bucket of water and put 3 pounds of shock in the bucket let it dissolve and slowly pour it in the pool. Is this correct? Or do I need to not put 3 pounds in at one time?
    Again thank you so much for your patience with me. I greatly appreciate it.
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,023
    Don't add all 10 bags at once.
    Scoop some pool water into the bucket, add the powder and stir it or swirl it, whatever. It'll take a few minutes to mix. It might take hours to dissolve 100%. Then treat it like bleach and dribble it in front of the return jet so it gets mixed and scattered quickly. Here's a thread from some folks that have used it. http://www.troublefreepool.com/threa...lving-Cal-Hypo
    Don't freak out of the pool gets cloudy. It will pass.
    May 2014
    Nevada, TX
    238
    How long after adding the stuff to the pool do I need to wait to swim?
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,023
    30 minutes ought to be plenty. You don't need to wait for the CYA to dissolve before you get in.
    May 2014
    Nevada, TX
    238
    Oh wow! The packaging said not to swim and less free chlorine was below four and this is supposed to bring it up to 12? Still safe? I obviously trust you experts on this forum more than a package product from Walmart just want to make sure. LOL
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    19,023
    If your CYA is 30, shock level is 12. It's safe to swim in. That's actually less aggressive than zero CYA and 3 FC. If you're doubtful about the CYA test you ran, wait a few hours. Brush the slime off while you wait.
    May 2014
    Nevada, TX
    238
    I trust ya Richard! I dissolved the shock and poured it slowly into the pool and used the brush from outside the pool to move it around a bit. Will run all tests again tomorrow and post results.
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Ok just 2 days ago I put in 3lbs of shock to bring FC to 12...today it is a 2.5???? Is this even possible for it to drop that far that fast?
    Today's numbers are:
    FC: 2.5
    PH: 7.2
    CYA: 40
    TA: 100
    CH: 150
    CC: 1
    TF-100 test kit
    May 2014
    Nevada, TX
    238
    Also... We did have some rain yesterday, but I didn't think it was that much that it could effect the numbers that much.
    TF-100 test kit
    Jun 2013
    Fallsburg, NY
    258
    Two days? You waited that long to test? FC is destroyed by sunlight and fighting organic compounds in your pool (including bacteria). Yes, it is certainly possible to lose 10 points in 2 days. You need to keep it at 12 until you pass the OCLT (overnight chlorine loss test) and have .5 or less CC.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by PridgNYC View Post
    Unfortunately, YES. I did wait that long to test again. we have some personal family things going on that is preventing me from taking care of it as timely as I should.
    TF-100 test kit
  20. Back To Top    #20
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,185
    Sorry for your issues....
    You need to test and adjust the chlorine level a minimum of twice a day while you are trying to kill the stuff that has taken up residence in you pool (what TFP calls a SLAM)
    Test water
    Adjust chlorine to shock level
    repeat
    Brush at least once a day
    This will clear up your pool the quickest.
    Support the site
