Thread: Chlorine masuring low with taylor K-2005
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    I have ordered the TF100 test kit, but am currently using my old Taylor K-2005. For FC, you add 5 drops R001 and 5 drops R002 to 9ml water and shake, then match color. I know my chlorine is high as test strip is at least 10, but the K-2005 is just showing a pale yellow. Could this be due to old reagents? What is the difference between the K-2005 Fc test and the FAS-DPT....
    Intex 15X48 metal frame - 4400 gallons - 8 years old!
    Intex SWG / Pump (sanitation) / Hayward pump (sand filter & heater)
    Hayward skimmer / Hayward Propane Heater 100,000 BTU / Hayward S144T Sand Filter
    Re: Chlorine masuring low with taylor K-2005
    The FC/TC test in the K-2005 reads zero when FC/TC is 12+. The FAS-DPD test we recommend reads FC/CC up to 50.
    poolsam's Avatar
    Jun 2014
    Bangor, maine
    66
    Does it turn a pale yellow with high levels, or could that indicate old / expired R-0001 or R-0002. My K-2005 is 2 years old..
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    The DPD reagent bleaches out at super high FC levels.
    You can check the reagent by testing your municipal tap water. It should show 1 or 2 FC.
