Thread: Testing boric acid before adding
    May 2014
    Dfw
    29
    Hi there. Been using the bbb method for a month or so with great success and consistency. I ordered plenty of boric acid from dudadiesel and am very impressed with that guy! My question right now is: myself being historically allergic to all things laundry soap and fragrance lotion/hand soap. Would taking a bath with a small amount of boric acid in the tub be a suitable test? Or is this the dumbest thing you have ever heard?
    I searched and didn't see anyone with complaints of rashes after boric acid but then again most people don't break out to the degree I am prone to.
    14k gallon, vinyl in ground, 1 hp pentaire pump, pentaire sand filter, taylor k2006 kit,hayward shark vac cleaner, pool blaster cg vacuum
    Donldson's Avatar
    NW Ohio
    2,892
    Re: Testing boric acid before adding
    Seems like a fair test, just measure carefully to make sure you only have 50 ppm in it. Not a fair test if you end up with 1000 ppm in your tub
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
