Thread: CC zero - is that a good thing?
    Hoochie's Avatar
    May 2014
    Newmarket, Ontario, Canada
    31
    FC 6.0
    pH 7.6
    TA 120
    CH 250
    CYA 70
    CC 0
    CSI -0.13
    If CC is zero is that an issue?
    Pool math says I'm balanced. Although given how fast the beers are disappearing I question that.
    H
    IG POOL: 100k litres/24k Gal, 2005 Mountain Lake SWG, vinyl,
    EQUIP: Hayward ProLogic P4 + Turbo-Cell-15 + 1HP Hayward Super Pump, Titan TIII 120k BTU Heat Pump, STA-RITE 300lb sand T-240BP-1,
    TEST: Taylor K2006 (FAS-DPD) test kit
    1f u c4n r34d th1s u r3411y n33d t0 570p r34d1ng 51g5 0n f0rum5
    38,274
    Re: CC zero - is that a good thing?
    Yes.
    Oops just saw you asked 2 questions with opposite answers. The CC should ideally be zero.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Combined Chloramine (CC) is something you DON'T want, so a reading of zero is great.
    In a balanced and properly chlorinated pool you might see 0.5 CC the morning after a heavy bather load, before the sun has had time to break them down.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Hoochie's Avatar
    May 2014
    31
    Thanks Gang!
    CC = zero. Good thing.
    Cheers
    H
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    You may want to work on gradually getting your TA down. It's a little higher than what's recommended for SWG pools.
    Hoochie's Avatar
    May 2014
    31
    Quote Originally Posted by JesseWV View Post
    Thanks Jesse
    That's exactly what I'm working on. My original TA was pretty high about 140 when I ran tests with the k2006. My pool store readings where much lower on their reports.
    My plan is to let my pH hit 7.8 and then knock it back down to 7.0 Let my TA drop.
    I don't thing I'll aerate and let my pH climb on its own. It seems to come up fairly fast. Friday 8.0 knocked to 6.8 ish, aerated Saturday and it climbed to 7.4. Rained last night. But today 7.6 - will test this evening.
    Thanks
    H
