Thread: No Chlorine!
    Apr 2009
    Louisiana
    64
    No Chlorine!
    This is our 5th year with our pool & the first time we have had problems with it. Our Jandy remote went out & have been working on replacing it. Our current readings are PH 8.2, CC 10, TA 110 & CH 90. If I'm correct, I need to add 112 ounces of bleach, 33 oz of muratic acid. 447 oz calcium chloride & 188 oz stabilizer. Should I do the acid first, then bleach? Thanks for your help!!
    19,000 IG Pacific Blue plaster,raised spa with spillover,rock waterfall, Jandy 2.5 HP pump,Pentair sand filter,Paramount in floor cleaning system, Jandy Aquapure SWG, Aqualink remote
    Re: No Chlorine!
    Yes, get the PH down to anywhere around 7.5 first. Then chlorine, then CYA/stabilizer.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: No Chlorine!
    Is the CC 10 a typo?
    What is the CYA #?
    You're done SLAMing when:
    Apr 2009
    Louisiana
    64
    Re: No Chlorine!
    The CC was 0 as well as my CYA! My FC was 1.
