Results 1 to 9 of 9
Thread: A leak around my skimmer
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Hey guys. I have a leak around my skimmer and it is really bumming me out. I did the install myself and followed the instructions to a T, and it leaked. I called the local pool guys to help out, 450 bucks later they installed another brand skimmer (Hayward). I had to drain half the water out and the top off for water cost me 140. I just don't know what to do. Do I call the pool store again and tell them they didn't fix it? Do you think I should pay for them to come back again? Should they pay for water delivery since they didn't fix it? I just don't know how to handle them. And I don't want them to take advantage of me.
    Or Is there some kind of epoxy I can shove under the white plate? To seal it up. I just don't want to have to pay 140 bucks each time they think they fixed it. Ya know. I'm just so upset right now.
    [IMG][/IMG]
    I appreciate any input or help.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: A leak around my skimmer
    Give it sometime and see if it stops. How long has it been since the re-due ? The gaskets need to get good and soaked with water to seal tight.
    I had the same problem with mine and after awhile it stopped.
    Jeff
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Since yesterday afternoon. So about 22 hours so far.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'd let it go for awhile and see what happens. Mine dripped for awhile before it stopped. Mine dripped just like in your pic.
    Make sure all your skimmer screws are tight. Check in a cross pattern or start from the inside and work your way around.
    Jeff
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Looking at the installation manual I found, there should be t-nuts on those bolts. Did the guys who installed it for you have experience working with Radiant pools? From what I've seen online they have a thick wall with a foam core. That is very different from the standard above ground pool. I would call them and let them know there is still a leak. After paying that much money you should have some recourse.
    If you still have the skimmer that came with the pool save all the pieces and call Radiant first and see if they can give you some help over the phone or determine if you have any missing pieces. Some nuts may be all you need to hold the skimmer together.
    Love TFP? Become a
    TFP Supporter!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Whoops didn't see it was a radiant. Zea maybe on to something.
    Jeff
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Quote Originally Posted by zea3 View Post
    Thanks for the reply. They guys that did the skimmer are a radiant dealer. In talking to them yesterday they say they do about 10 radiant each summer. That is why I called them. I figured I would pay a little more but they knew what they are doing. I bought the pool online after they quoted me 2k more. The local guys said the skimmer that came with it was junk so they recommended I have them install they Hayward. I was ok with that as I just want it done right without leaks.
    I checked the manual and the bolts are in correctly. It does say to firmly tighten them but don't over tighten. Lol. WTH is that. Woman tight? Haha
    Quote Originally Posted by pwrstrk View Post
    I'll check tightness after dinner. When they were filling the pool it didn't leaked at all. Three hours later I checked and that as when I noticed it leaking.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Woman tight lol. That'll stir things up. Not over tight. Just nice and snug !
    Jeff
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Actually found the issue. There is a pin hole above my return jet. It was filling up behind the liner and pushing out behind the skimmer. Talk about relief.
