How to connect a new pump
Yaniv
0
149
San Jose, CA
Weird question i know, but i got a new Hayward pump and screwed in the PVC fitting using teflon tape, i didn't use PVC glue on that part because it needs to be disconnected in the future.
it always leaks no matter how hard i tightened it and how much teflon tape i use.
Should i put PVC glue there? or is there a different way to connect the pvc adapter?
Yes the pipe dope is better on large dia. fittings.
Most important do not over tighten or you run the risk of cracking the female end of the pump. Hand tighten. The male end of the fitting has a slight taper to it. There will still be threads showing when it's tight enough.
