Thread: winterizing liquid chlorine dispenser
    Jun 2014
    Burlington, Ontario
    59
    So I'm putting in a stenner pump and I am curious... Is there anything special you do for winterizing the system? It goes way below freezing here.
    16' wide ~20,000gal IG vinyl lazy L shape pool circa 2002, 1hp Hayward Super Pump, Hayward S244T sand filter, Hayward H250ED2 gas heater, Hayward eVac Pro robot, Stenner pump for chlorine, TF-100 test kit
    2008 Gulf Coast 864 LEi hot tub
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,191
    Re: winterizing liquid chlorine dispenser
    Well, my first reaction is to look to chem geek, where he said:
    Quote Originally Posted by chem geek View Post
    The freezing point depression for 6% Sodium Hypochlorite as found in Clorox Regular and most Ultra brands of bleach is 7.3C or 13.1F so the freezing point is -7.3C or 19F.
    The freezing point of full-strength Muriatic Acid (31.45% Hydrochloric Acid) is -46C (-50.8F) (for Hasa; other brands quote even lower freezing points) so unless you live in the Artic, I think you are safe to leave your Muriatic Acid outside.
    I'm going to guess it gets below -7.3C or 19F in Burlington, Ontario so you will have to deal with it.
    I would pull the tubing out of the pump and move it and the bleach container to a location that it won't freeze.
    Support the site
    I take the pump head indoors for the winter.
    Jun 2014
    Burlington, Ontario
    59
    Figured as much. Thanks. It does hit -30C or so at least a couple of times each winter.
