Results 1 to 20 of 20
Thread: Sudden air in my returns?
    Jun 2014
    The Woodlands, TX
    167
    Hello all:
    New pool, build thread is linked in my signature. Had it up and running about 30 days.
    My PB stopped by on Friday to start up my salt water generator. Since then I have noticed constant spurts of air from only TWO of my four returns. They are both on the same side (far side) of the pool in relation to my equipment. I have been told that SWG causes bubbles, but this is a "spurt....spurt....spurt....spurt" every 3-4 seconds, and it's kind of a big burst. It sounds annoying when you're under the water.
    I have tried everything to bleed air, including opening up both pump covers, and bleeding air out the bleed valve on the top of the filter. The PB says he didn't open up the salt cell or touch anything, although he DID state that he was running the filter on drains only, not skimmers, to suck down some of the salt.
    Any thoughts?
    8,000 gallon in-ground gunnite geometric. Wet Edge Satin Matrix. Triple overflow water feature.
    Hayward - TCell 15 SWG; TriStar VS Main Pump; SwimClear 425 Cartridge Filter; ProLogic 4 Automation, SuperII Water Feature Pump; Polaris 280 w/ Booster
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Sudden air in my returns?
    Is this happening on less that full speed? If so, it is normal. The gas bubbles from the SWG collect in the pipes and then burp out occasionally. The flow rate is not sufficient to continually purge the gas. This happens to mine on low speed as well. On full speed, you should just get a lot of little bubbles.
    Mark
    Jun 2014
    The Woodlands, TX
    167
    Yes, less than full speed.
    But it's not occasionally. It's constant.
    Link to my Build
    Jun 2014
    The Woodlands, TX
    167
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    That is a bit more air than what would be caused by an SWG so it is probably an air leak. Do you see air in the pump basket?
    Also, because you are on main drains only, the suction could be quite high in the pump basket so it might be drawing in air.
    Mark
    Jun 2014
    The Woodlands, TX
    167
    No air in the pump basket.
    I'm back to both main drains and skimmers.
    Also, only coming out of two of the returns....sounds fishy to me. How would I all of a sudden develop a leak this severe in one day?
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    The only reason that the air is coming out of only two of the returns is probably because those returns are higher than the other returns and on low speed, the air follows gravity as well as the flow rate. So that part is not that meaningful and has more to do with the flow rate than anything else.
    So what happens when on full speed? Also, what is the filter pressure on full speed?
    After running on high speed for a few minutes and then dropping down to the lower speed, does it take some time for the bubbles to show up again or is it immediate?
    Mark
    Jun 2014
    The Woodlands, TX
    167
    So my pump runs at 30% during the late morning and early afternoon, and back up to 50% at 2:00 PM. When I went outside at 2:00 PM, there were bubbles coming out of the returns. There were also bubbles in the pump basket.
    I turned everything off and ran the following experiment:
    1. Opened the cover on the pump basket and allowed water to drain down.
    2. Turned on pump. Pump automatically goes to 100% power at times during startup (have not figured out this logic). In any event, that time is usually 2:30, and so it was. At this time pressure was 22psi.
    3. Pump down to 70%. Psi dropped to 16 psi. Ran for 6 minutes. No bubbles in the basket, no air coming out of returns.
    4. Pump down to 50%. Psi dropped to 6 psi. Ran for 10 minutes. Tiny bubbles in the basket, air coming out of returns.
    5. Ran pump another 10 minutes. Tiny bubbles (like 5) still there, but no more. Amount of air did not change.
    Have not reduced pump speed as 50% is it's normal afternoon run speed.
    Link to my Build
    Jun 2014
    The Woodlands, TX
    167
    30 minutes later, pump speed still the same....now there are large bubbles in the pump basket and lots of air coming out.
    I also hear something gurgling around in the area of my cleaner booster pump. Could that have anything to do with it?
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    The air in the pump basket indicates a suction side air leak somewhere and probably what is causing the bubbles although the SWG may be contributing. If you want to make sure, shut off the SWG completely and rerun your experiment and see if the results are the same. But either way, you still have an air leak in the suction side somewhere.
    Mark
    Jun 2014
    The Woodlands, TX
    167
    OK, so now I have a lot of air in the pump basket. However, there is NO air coming out the returns whatsoever.
    More tellingly, the SWG is off.
    How could I all of a sudden developed an air leak on the suction side? Or maybe it was there all along and I didn't notice air in the basket because I didn't have air from the SWG?
    Oy vey.
    Link to my Build
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Are your skimmer baskets clean? Air can be sucked there if skimmers are full of leaves.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    Jun 2014
    The Woodlands, TX
    167
    Skimmers clean. We have no leaves here anyway.
    Link to my Build
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    I would get the builder involved and have them do the leg work to figure it out. If they can't figure it out then fight, if you have to, to get a leak detection company involved to figure it out, if it is a leak. The builder should be able to run a pressure test on the pipes to rule out a leak in the pipes. Don't let them off the hook until you get this figured out.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2014
    The Woodlands, TX
    167
    Spoke to my PB. He is still researching the info on the SWG / air. But I will say that he is pretty adamant about air building up in the basket from the variable speed pump. He notes that on lower speeds, air will gradually build up in the basket, but will be pushed out and stay out when pump is on high volume.
    His statement mirrors my observations from yesterday. Sunday night there was all kinds of air in the basket chamber. Yesterday when the pool had just completed a 3 hour run at 70% speed, the air was all but gone, and there were some small bubbles. By last night, the bubbles were larger again.
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    What you are describing is normal but from what I understood about your situation was that you were also get air out of the returns on low speed with the SWG off or did I misunderstand.
    Mark
    Jun 2014
    The Woodlands, TX
    167
    No air out when the SWG is off. Sorry for confusion.
    Link to my Build
    mas985's Avatar
    Pleasanton, CA
    11,741
    Ok then the SWG is clearly causing the air out of the returns which can be normal although from the video, it looked like a lot more than what I am use to.
    Also, after running on high and then switch to low, if it takes a long time (hours not minutes) before air builds up in the pump basket, then it is probably a common condition. Either a very slow leak or out gassing. But if you have a high speed cycle each day, it shouldn't be a problem.
    Mark
    wjr75's Avatar
    Jun 2013
    IL
    836
    Did you bleed your cartridge filter. Mine has a bleeder on top of it which you open to let pressure out before cleaning. After I clean I open it up with the pump running until you get a constant flow of water. Forgot to do it this year after my first clean and I had a lot of bubbles.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
  20. Back To Top    #20
    Jun 2014
    The Woodlands, TX
    167
    Yup, bled the filter. And both pumps.
    Link to my Build
