timerguy
0
About 10-11 inches should do it that's 17% that'll get you close enough I would think.
Ok, I went to Walmart and bough 10 8.5% 121 oz bleach jugs. A 50 cya level requires 20 FC for shock by the pool calculater. I put it into the chlorine calculator and I would need to use 5 jugs to get to 20. Does that sound right? Also should I measure the chlorine level after I shock it or wait a while? Then how frequently should I check and see the chlorine levels and add to it if need be? I work 8 to 5 tomorrow but can come home at noon. Then each night I need to check to see if it is less than a 1ppm drop in chlorine. When this happens I can stop maintaining the shock. Does this sound about right? My Free Chlorine is 0 and my combined Chlorine is .2. (It was barely pink)
I bet he sold you more stuff tooMy first two years i spent 500 plus dollars and still had issues. I would wander around the pool store until i saw the manager and then i would latch onto him because he explained things better than the young kids that worked there. Now i control my own pool.
