Thread: Combined Chlorine & Shock ?
    Jul 2014
    Granville, MA
    2
    My pool has been & still is crystal clear with no algae, but after reading the info here I decided to get the Taylor K-2006 just to make sure everything is in balance and safe. Here are my first readings: FC=4ppm, CC=1.4ppm, TA=120, pH=7.4, CH=200, CYA=70.
    So I then shocked the pool using liquid chlorine(Sodium Hypochlorite). I put in 3 gallons which I got from using the calculator which brought it up to 29ppm of FC. Just above the suggested shock target. Now 3 days later checking the numbers I get: FC=11.6ppm, CC=1ppm, TA=130ppm, pH=7.6, CH=200, CYA=70. I thought the shock treatment would eradicate the CC. Am I missing something? Do I need to repeat the shock again until the CC reads 0? This is an above ground 24' diameter 52" high pool.
    Thanks for the help
    Size : 24' Diameter 52" high A.G
    Gallons : 14,500
    Filter : Hayward Perflex Extend Cycle D.E.
    Pump : Hayward Power - Flo Matrix
    Test Kit : Taylor K-2006 Complete (FAS-DPD Chlorine)
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Combined Chlorine & Shock ?
    Welcome to TFP!
    "Shocking" a pool is not a one-time event, it is a process which we refer to as the SLAM Process. The FC must be maintained at the recommended shock/SLAM target until
    1. CC is 0.5 or lower;
    2. You pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    3. And the water is clear.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,573
    Sounds as if you stopped the SLAM process before passing all 3 criteria. Have you passed the OCLT?
    Jul 2014
    Granville, MA
    2
    OK Looks like I didn't follow the steps correctly. I will maintain the FC to shock levels until I pass the OCLT and .5 or less of CC. Thanks for the help.
    Gallons : 14,500
