Results 1 to 7 of 7
Thread: FC Levels
    Jun 2014
    Queenstown, MD
    25
    FC Levels
    I generally test water and add liquid bleach in the mornings. Several times a week, FC will register at 1 to 1.5. I add enough chlorine to shoot for FC=4. Should I be adding more bleach to keep the FC level at or above 2?
    pH=7.6
    TA=80
    CH=40
    10000 IG plaster pool / Pentair Clean & Clear Plus 420 sqqft cartridge filter / Aqua Rite SWG T-15/ Taylor K-2006 Test Kit
    May 2013
    Bay City, Michigan
    283
    Re: FC Levels
    Your FC level is entirely dependent on your CYA level, which i don't see listed.
    http://www.troublefreepool.com/conte...ater-chemistry
    CYA - Cyanuric Acid - Protects chlorine from sunlight and determines the required FC level. (outdoors 30 to 50, SWG 70 to 80, indoors 0 to 20)
    Chlorine/CYA chart - http://www.troublefreepool.com/conte...art-slam-shock
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: FC Levels
    Depends on your CYA, you might need a higher minimum FC.
    Jun 2014
    Queenstown, MD
    25
    Re: FC Levels
    Yes, forgot to add CYA=30
    May 2013
    Bay City, Michigan
    283
    Re: FC Levels
    Yes, with 30 CYA, your minimum is 2. You either need to add more often, (many do daily) or increase your amount so it does not fall below 2 by the next time you add more chlorine
    Jun 2014
    Queenstown, MD
    25
    Re: FC Levels
    Got it, thank you for confirming.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: FC Levels
    You should try to maintain 4 at all times and not drop below 2 to keep from having a problem. If you can't test and adjust daily you might want to go a bit over 4 so you stay above that 2. If you record your tests for a week or two you can see what it takes to keep it in the proper range.
    Solar Blanket, Well Water, Borax Added. 68
