I'm a new pool owner, thought everything was going great, water is crystal clear, but sides and bottom of pool are getting slick. Algae??? Tested levels, did the pool calculator.
FC-0
PH-8.4
TA-240
CYA-100
Pool calculator says add 31oz of 6% bleach, and 14oz of 31.45% 20 Muriatic acid
Is this correct?
Do I add the bleach first and test again, before adding acid?
Do I run SWG while doing this or pump only?
Thanks for any advice.
FC-0
PH-8.4
TA-240
CYA-100
Is this correct?
