Thread: Second season using TFPC Method
    SJS101's Avatar
    Apr 2013
    Louisiana
    14
    Ignoring the few little spots of dirt near the drain and along the left side of the decline, this is the result of the knowledge I have learned here. For all those fighting the good fight, best of luck and crystal clear sparkling water is on it's way if you follow the advice given!
    18 X 36, 29 K gallon, Sand Filter, Inground Vinyl Lined, 3/4 HP pump
    38,521
    Re: Second season using TFPC Method
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Great Job! Looks like you will be doing more of this due to your sparkling pool.
