Thread: My DIY aerator...
    Back2BasicsMom's Avatar
    Jun 2014
    Central MN
    19
    My DIY aerator...
    Hi there, I'm new to the forum and a first time pool owner. I've been doing lots of reading and learning a lot! I decided I needed more aeration since my TA has been a bit high, and reading all I could about lowering it here... http://www.troublefreepool.com/conte...tal-alkalinity
    Here is what my hubby and I came up with
    It took a bit of trimming and sanding to get the PVC to fit right but it works great. Can't wait to test my levels tomorrow!
    Thanks so much TFP!
    18' x 48" Above ground Intex metal frame 6,423 Gal
    Purchased Used (Approximately 3 years old) but new to us.
    110-120 volt Filter Pump with 1,500 gallon (5,678 L) per hour flow rate (Intex)
    Water is from a well
    Casey's Avatar
    SW PA
    10,461
    Re: My DIY aerator...
    You'll need the MA to drop the pH and then aerate it back up. Looks great! Let us know how you do.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    (MA = Muriatic Acid, by the way)
    Jun 2014
    Central MN
    19
    Yup! Got it Casey, Just thought the aerator was pretty cool
    Thanks Chem Geek!
