Thread: Pool drain making pulsating noises
    Jun 2014
    Franklin, Virginia
    13
    Hello,
    I originally posted this question in the wrong section. I'm hearing pulsating sounds coming from the pool drain. Even when we turn the pump off it's still pulsating. What is causing this? I tried backwashing, going to rinse then back to filter but I still hear the noise. Should I call a plumber or a pool tech?
    32900 K Gal, IG, Vinyl, Hayward Aquarite Salt Gen, Sand, SWG, Manual vacuum cleaner
    Casey's Avatar
    SW PA
    10,461
    Re: Pool drain making pulsating noises
    Hi Nikki, Not sure but I know someone here knows and can probably help you.
