Thread: Replacing Single Speed Motor w/ Dual Speed Motor
    Sherra's Avatar
    Jun 2007
    South Carolina
    11
    Arrow Replacing Single Speed Motor w/ Dual Speed Motor
    Is it possible to replace just the motor on my current single speed pump with a dual speed motor, or do I have to replace the whole pump?
    If I can replace just the motor, does it have to be the same manufacturer, or do I just need to make sure it fits & has the same THP (hp x sf)?
    Am I going to have something special done to my wiring? The pump is hooked up to a timer.
    Here is the label from my current pump.
    Sherra
    Kershaw County, South Carolina
    18x36 27,500 gal IG Vinyl Liner, sand filter, 1hp single speed pump running 6 hours twice per day, Hayward Swim Pure salt chlorinator, 2 skimmers, main drain, 3 returns, husband, 2 kids, 3 dogs, 2 guinea pigs
    38,271
    Re: Replacing Single Speed Motor w/ Dual Speed Motor
    You can replace just the motor with any brand 2 speed motor, just match the SFHP and frame shape. You will also need a new shaft seal and to add a switch to select speed after the timer .... like a house 3 way light switch.
    Jul 2014
    Goodyear,Az
    7
    This would be a great diy project! I need to do this.
    12,000 gallon pebble tech, caretaker 5 port,hayward super2 w/ 2hp motor,DE 48"
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I believe the replacement two speed motor for that pump would be the the A.O. Smith B2982.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
