Results 1 to 8 of 8
Thread: You told me....
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    You told me....
    Just have to say you all were right! We put in the pool over the winter, you may remember what an ongoing challenge it has been and I ordered my test kit. I have to tell you being a newb it was a bit overwhelming but the instructions were detailed and easy even for a greenhorn like me to understand. I've been testing and watching the water, yesterday I realized you all were right I looked at the water and told the husband, I need to add acid before I even tested it. He thought it looked fine and being a chemist by trade wanted to debate it, so I grabbed the test kit and sure enough, the ph was a little high. He was amazed! I told him the folks on the TFP site said you get to the point where you can tell even if it's a bit off just by looking at it! Thanks again for all your help!
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: You told me....
    You have better eyes than I do if you can just "look" at the water and tell if the PH is off! I have a hard enough time matching the colors testing it. Care to share any tips or secrets regarding the "eyeball" test?
    38,235
    Re: You told me....
    The pH should not really cause a difference in the way the water looks ... If the FC gets too low, that can cause a dullness.
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Re: You told me....
    I think OP may have meant "based on the pattern I have observed while maintaining the pool the pH is probably low at this point".
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Sep 2013
    DFW metroplex
    738
    Re: You told me....
    As I've checked the water and tested it - the sparkle isn't there on the days the ph is high - my FC has remained at the 3 - 4 level but when the ph hits above 7.8 - which it does every few days since it's fairly new plaster, I notice it's not as sparkly. I guess I'm imagining it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: You told me....
    I get the same. I always blamed it on my astronomical CH. When pH is low, the water is much sparklier.
    Re: You told me....
    I can tell at a glance when the pH in the hot tub is way too high. It just looks, I dunno, thicker somehow. Probably because the alkaline water has slightly different light bending/refracting characteristics.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    Sep 2013
    DFW metroplex
    738
    Re: You told me....
    Thanks guys - I didn't think I was imagining it - I'm good, just not that good! Thicker is a good word for it! And btw Richard, my Ch is 850!!
