Thread: Maintaining chlorine level
    Just curious about maintaining chlorine level. How often should I be adding bleach to my 27k pool if all reading are correct? Pool is in full sun all day. Reason I ask is I am about to get into some OT at work and I dont want to fall too far behind on Pool duties, as when I am ready for a dip I dont want any surprises!!!
    Re: Maintaining chlorine level
    Once a day is the most common routine.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by bowlinmark View Post
    You could think about getting a SWG or a liquidator or stenner pump to dose FC for you
    You're done SLAMing when:
    JasonLion once a day, is this adviseable at night when the sun has gone down?
    Butterfly which is the most economical?
    27K gal, vinyl, 1 HP Challenger pump, 300 # sand filter, Hayward Navigator/Manual backbreaker
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Bowlin69 View Post
    Most would say add in the evening when the sun is off the pool and you have at least 30 minutes or so of the pump running to circulate the chlorine before the pump shuts off.
    All three methods have their pluses and minuses which may be different for individual pools. Do a search for each one and do a little reading about them. I have a Stenner, but it may not be the best solution for everyone.
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    +1 to what Tim said ^^^^
