Thread: Pump/filter upgrade
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Pump/filter upgrade
    As you can see in my sig, I have the standard Intex cartridge pump that came with the pool. Today my wife brought home an Intex sand filter/pump that is .75hp and 2150 gph (model SF70110).
    All I've done so far is read part of the manual.
    In my reading, I came across this piece of information about care for the pump:
    • Provide a location protected from the weather, moisture, flooding, and freezing temperature.
    So, that presents a problem. Protected from the weather? I've seen so many people that just have their pumps sitting out next to the pool. Does it need some sort of shelter? My current pump is sitting on a 16"x16" piece of concrete, about 1 inch above ground. Would that be sufficient to keep it off the ground?
    It also said I needed No. 20 silica sand. Is that the same recommendation from TFP?
    Thanks folks!
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    38,290
    Re: Pump/filter upgrade
    That is the only sand you should use in filters. As far as protection, depends on your environment. A cover to block rain and sun is good, but most people do not do it. just don't leave it out in winter.
    Mid Missouri
    227
    I have an Intex sand filter similar to yours. It is in it's second season unprotected. No issues or signs of any issues thus far.
    Well before freezing temps arrive I bring the pump portion inside. I winterize the the filter (16" 100lbs sand) portion by removing the drain cap, sight glass, gauge, and put the valve in the N position. I think it's marked N on the valve position, it's the one that holds it like you're pressing down on the handle.
    Oct 2012
    Houston, TX
    186
    3rd year sitting out in Houston sun. No signs of wear. Luckily the house shades it from late afternoon west exposure.
    I wouldnt worry about it if I were you. Worst case, replace after several years. For the cost, no big deal.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    So I'm trying to hook up PVC to the drain on the filter so it doesn't spew water all over the side of my house, and the fitting screws on, but only part of the way. I could probably wrap a couple of layers of teflon tape around the threads so it doesn't leak (I am afraid to tighten it down) and hopefully that will last the rest of this season. Is there some sort of adapter that will match the Intex threads to standard threads on PVC?
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by Chewbubba View Post
    Here is an adapter you can make if you have an extra hose to cut up for it.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
