Results 1 to 12 of 12
Thread: 12 day vacation
    Jul 2014
    Broken Arrow, OK
    6
    12 day vacation
    We are leaving for almost two weeks. The pool is new. We can set the variable speed pump on a timer. My thoughts were to shock the pool, leave our cleaner in the pool and set the pump to run 3 hrs at 3450 rpm so the cleaner works, and then run at 600 rpm the rest of the day. Any thoughts on this? We also have an auto fill so I'm not worried about adding water. No trees so the only debris would be bugs and small dirt particles due to construction next door.
    Thanks for the help!
    23k, Gunite, Pebble Tec White Diamonds, Two Skimmers, Two Deep Drains, LED Watercolor Light
    Jandy Sand Filter, VS FloPro 1 HP Pump w/ ePump Controller, Quickpure 3 Ozone System
    Zodiac FloPro 2 HP Pump for Paramount Jetpaks
    Hayward Pool Vac XL
    Casey's Avatar
    SW PA
    10,453
    Re: 12 day vacation
    SLAM the pool according to your CYA and cover it with a solar cover. It will keep the sun from burning the FC off even faster and you can deal with it when you get home.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: 12 day vacation
    Have any friends with pools who would "pool sit" ??
    Solar Blanket, Well Water, Borax Added. 68
    Jul 2014
    Broken Arrow, OK
    6
    Re: 12 day vacation
    Thanks for the reply. Do they make solar covers for free form pools?
    I don't really have anyone I trust to pool sit unfortunately.
    Hayward Pool Vac XL
    Casey's Avatar
    SW PA
    10,453
    Re: 12 day vacation
    No, you can buy a big one and cut it to fit. That's what most people do. Sometimes, if the pool is really big, they just leave that one piece that isn't covered open. It won't hurt anything.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Re: 12 day vacation
    12 days is a long time. I would consider adding some polyquat 60 if you don't have anyone who can top off the chlorine while you are away.
    Love TFP? Become a
    TFP Supporter!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: 12 day vacation
    Quote Originally Posted by jwsmartin View Post
    I've never been away that long but any chance you could hire a "pool guy" while you're gone ??
    Jun 2014
    Central Florida
    36
    Re: 12 day vacation
    I know they are recommended against for long term use because of the added CYA, but could this person use slow dissolving sticks to maintain a safe amount of chlorine while on vacation?
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Jul 2009
    Houston, Texas
    9,412
    Re: 12 day vacation
    Quote Originally Posted by Tedb View Post
    Tabs in a floater would help for about 7 days, but only if their CYA is low enough that using the tabs is not going to create more of a problem.
    Love TFP? Become a
    TFP Supporter!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: 12 day vacation
    The pool is new.
    How new? If you are still managing rapidly rising pH and balancing the pool, you need to make arrangements to have it cared for. Also, leaving a new plaster pool unattended could damage the pool and could void warranties.
    So, exactly how old is this new pool?
    Welcome to TFP
    You're done SLAMing when:
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: 12 day vacation
    Quote Originally Posted by zea3 View Post
    And if the OP had anyone that could come by in a week and toss in another chlorine tablet it would be something to get him by.
    Jul 2014
    Broken Arrow, OK
    6
    Re: 12 day vacation
    I talked to the guy who trained me on chemicals. He said to add 6 lbs of chlorine and throw 3 sticks in each skimmer and leave the pool circulating at 1200 rpm uncovered with no cleaner running.
    The pool was finished in May. We do not have much issues with PH rising. I have only had to lower it once based on tests.
    If the only concern is adding chlorine, I could probably ask a neighbor to shock it half way through the trip.
    Thanks for all the replies. Pool has done very well so far besides occasional cloudiness from dirt.
    I'll post results when I get back. Any more advise is appreciated.
    Also, I just tested the water today and got the following.
    Hardness <100
    FC 1
    pH 7.5
    TA 80
    CYA 30-50
    Hayward Pool Vac XL
