Results 1 to 7 of 7
Thread: Polaris 280 normal operation at hose connection?
    delirium330's Avatar
    Dec 2013
    Sacramento, CA
    104
    I've running a Polaris 280 cleaner and just got a new booster pump for it (PB4-60 Zodiac). Running my main pump at 2k RPM during the daily Polaris cycle. Just noticed this for the first time, but there is a intermittent high pitched whining noise (pressurized air) at the connection of the Polaris hose. I also see high pressure bubbles getting pushed out where that little black cap is located (see picture). Is this normal operation and that connection is made to be an air release or do I need to replace some parts to eliminate an air leak?
    Built 2003, 14k Gallons, IG Pebbletec, Primary Pump: Sta-Rite Intellipro VS, Sta-Rite Series 3 S8M150 Cartridge Filter, Fiberstars Jazz Light w/Color Wheel, Polaris 280 Vacuum (Runs Zodiac PB4-60 Booster Pump) and 2 Waterfalls (Run on separate, dedicated 1HP Sta-Rite Max-E-Glas II Pump).
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Polaris 280 normal operation at hose connection?
    That piece is the pressure relief valve. Some flow of water through there is normal. I might expect some bubbles when the booster pump kicks on, but I wouldn't expect any bubbles after a minute or two.
    Are you sure the intermittent high pitched whining noise is coming from there? The intermittent high pitched whining noise I associate with my Polaris always comes from the backup valve cycling on.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Dec 2013
    Sacramento, CA
    104
    Quote Originally Posted by svenpup View Post
    I did notice the bubbles and whining right when the pump turned on, but will watch for it after a few minutes throughout the cycle. If it is ongoing/continuing past the first few minutes could I have my primary pump at 2k RPM too fast? The booster pump is the standard 1/2hp.
    What is the "backup valve" referring to that cycles on? I'm pretty sure it is coming from that connection... but could be wrong.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    This is a backup valve:
    It has a clockwork mechanism inside that turns with water flow. At intervals (every 5 minutes or so) a valve is opened and water flows through the jet. This will "fly" the polaris around the pool. This increases the randomness and also helps get it unstuck if gets trapped on stairs or something.
    wjr75's Avatar
    Jun 2013
    IL
    836
    My polaris 280 has a screen in that cap where your arrow is. You need to take it out and clean out the gunck.
    I should also note that mine is probably 10 plus years old and looks to be sucking water inward..so it is not a pressure release in my case.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2009
    Gonzales, La
    220
    There are also two different flow orfice plates that go either inside that or the fitting screwed into the return. A red one and a blue one. The smaller one may be installed and it may be making alittle noise.
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    Jul 2017
    Maryland Heights, MO
    33
    I was going to start a new thread but the picture on the first post in this thread is exactly what I have. I tried starting the Polaris today and it would run about a minute and a portion of the black O Ring that goes into the wall of the pool slipped out causing a loud squealing noise. Should I just replace that O Ring or is this a sign of something else wrong?
    30,000 IG Vinyl pool, Hayward Aqualite SWG, Sand filter, Pentair Superflow VS Variable Speed pump. K-2006 test kit. Pool built in mid 90's. Polaris Auto cleaner
