Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Ascorbic Treatment to rid Pool of metal stains
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I was reading this it said to circulate the water, and then put it on filter, I don't have away to bypass the filter to circulate the water....should I add a bypass after the pump to bypass the filter in these cases?
    Thanks
    even though my pool chemistry is right on according to Taylor 2006, I started to get these brown stains, there is also a larger stain around the main drain, they started with a few round dots that did not brush away, but MA does remove them...
    FC 6.5
    CC 0
    PH 7.6
    TA 75
    CH 350
    CYA 75
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Re: Ascorbic Treatment to rid Pool of metal stains
    You can do the entire AA treatment in filter mode if you don't have any way to bypass the filter.
    Make sure you test with a vitamin C tablet to see if that will remove the stain in a local area before doing the full AA treatment. If the vitamin C tablet doesn't work, the AA treatment won't work.
    There aren't enough situations where you need to bypass the filter to really justify adding a filter bypass. However, if you are upgrading the filter for some other reason, I would switch to a rotary multi-position valve.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    OK will try the vitamin c, I know MA takes it out, but want to stop them from forming.
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Do you think using lead fishing weights to weigh down the vitamin c sock a bad idea since its metal?
    Thanks
    Autopilot SWG
    Correct, bad idea.
    A vitamin C tablet should settle to the bottom and stay there on it's own.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    You do mean more than one tablet, in a nylon sock....
    Autopilot SWG
    You could do that, but I was thinking of a single vitamin C tablet.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by JasonLion View Post
    Thanks for the help, when you say vitamin c tablet, you do mean what a person would swallow? I am still new to this so want to be sure...
    Autopilot SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    Yes, a cheap vitamin C tablet. If you want, you can crush some up in a sock and hold/lay it on a stain. But, one tablet should do it just to verify if it works.
    You're done SLAMing when:
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by Butterfly View Post
    if the vitamin c removes the stain, and you only have a few spots, and you remove them with the vitamin c, do you have do the AA, or will they just come back, why do metal stains appear? When I first took control of the pool from the pool company, the FC was at 16, but there were no metal stains..strange
    Autopilot SWG
    Butterfly's Avatar
    South Carolina
    10,045
    If you only have a few stains, you could just use the crushed vit c in the sock method and move it around.
    The metals causing the stains are coming from somewhere. You need to find the source and stop it, if possible.
    To keep the stains from redepositing, you should add one of the recommended sequestrants.
    Have you had your fill water tested for metals?
    Is your fill water from a well or municipal water?
    Have you added any algaecides containing metals?
    Keeping pH under control is important. Has pH been high lately?
    What is the pool surface? You can add that info in your sig for us.
    Can you post a full set of test results for us?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    My test results
    FC 6.5
    CC 0
    PH 7.6
    TA 75
    CH 350
    CYA 75
    I just checked I did add algaecides, and it did contain copper..I did put a 1000 g viatamin c tablet on the stain, but it hasn't done anything yet.
    City water, plaster pool...
    I added the algaecide because I thought it was algae...
    Autopilot SWG
    Butterfly's Avatar
    South Carolina
    10,045
    If you bought/used the more expensive Vit C tab, they are coated and may take longer to dissolve. You could still crush some in a sock
    okay, no more algaecides for you! .....unless it is polyquat 60 - no harmful side effects.
    What is the pool surface? vinyl, FG, plaster?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Pool is Plaster, I did add it to my signature, just now...Thank you
    Autopilot SWG
    Butterfly's Avatar
    South Carolina
    10,045
    okay, thanks! If the vit c does not lighten the stain (after crushing some in a sock & trying it), try laying a trichlor puck on it for a few minutes.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    The two spots that I put the vitamin c on turned darker around the stain spot I had, I tried brushing the larger area and it did nothing, I removed the tablets, the stain was bigger. I took my pvc pipe and set it over the stain and poured MA down the pipe which made the stain and the area light again...will try the puck now..
    Autopilot SWG
    Butterfly's Avatar
    South Carolina
    10,045
    The best treatment for copper stains is to never get them in the first place
    They can be very difficult to remove, (often requiring a full drain and manual acid wash).
    Since you do not have many, use your MA-down-the-pipe method
    Good luck and post some pics for us.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Is it common for the metal stain to get bigger when you put vitamin c tablet on it? When I did mine the area around the one round stain spread...I think it was dissolving the stain...
    Autopilot SWG
    No, that is not common. It is possible for the vitamin C to lift the stain in a local area, only to have the metals redeposit nearby, but that is not common.
  20. Back To Top    #20
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thanks Jason
    Autopilot SWG
