Thread: Started shocking pool today for the first time I have a Question.
    May 2012
    Oconee, Georgia
    82
    25000 gallon vinyl pool IC40 Salt Gen
    FC 4
    TA 80
    CH 250
    CYA between 70 80 hard to tell
    That was at 8 am this morning
    12:15 Got CL to 24
    1:15 CL 28
    3 CL 23 added 2 gallons of bleach to bring back up to around 30
    how much should I be losing in the middle of the day between checks?
    May 2013
    Bay City, Michigan
    283
    Re: Started shocking pool today for the first time I have a Question.
    A clean and clear pool would normally lose between 2-4 per day, but if your SLAMing, you must have water issues that your trying to clear, and there is no normal loss rate when dealing with organics and the sun. If you want an idea of whats going on with your water, see how much you lose overnight without the sun.
    Just keep checking often enough to keep your FC at or above your SLAM target. If your not sure between 70 and 80 go with 80 and a FC level at or above 31 as much as possible
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    May 2012
    Oconee, Georgia
    82
    The pool is very clear has been the whole time just having to run my cell way too much. Had it in super chlor mode for 24hrs and my level was just 4 usually when I do that my level will be aroun 12.
    Jun 2014
    Central Florida
    36
    I'm just new here but if I read that correctly and you lost 5 ppm in less than 2 hours, that does sound like a problem, otherwise I would wonder if there was a problem with your cell. I'm sure the experts here will help you figure it out.
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    May 2013
    Bay City, Michigan
    283
    Quote Originally Posted by Tedb View Post
    That is how I read it and it definitely is a problem. Follow the directions for performing an OCLT, making sure to turn your SWG off and not using anything that adds chlorine! My guess is that if you lost 5ppm in 2 hours, you will fail the OCLT and the next suggestion will be to remove your ladder and any lights you may have and continue to SLAM until you pass the tests.
