Thread: CYA and Vacuuming
    Jul 2014
    BH (Saratoga Area), NY
    62
    CYA and Vacuuming
    If I put the solid CYA in the skimmer (in one of those mesh bag deals) how long before it (84oz) typically dissolves so that I can vacuum or do you just take it out and vacuum than put it back in?
    Upstate, NY, Direct Sunlight, Above Ground (18'x 33' x 4'), Oval 15700 gallons, Vinyl; Hayward S180T sand filter; 1 HP motor; TF-100
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: CYA and Vacuuming
    It is best if you take it out of the skimmer and hang it in the pool in front of a returning jet. You don't want the CYA to get stuck in your filter or risk clogging your plumbing.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    In front of a return jet it usually takes a couple of days to dissolve. Putting it in the skimmer takes longer IIRC. The other good thing about hanging it from a stick in front of a return jet is that it doesn't interfere with anything you want to do with the pool, unless you poke your eye with the stick.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    Jul 2014
    62
    Thanks, I figured it out. Seems to disperse quickly in front of the return. My 42 oz bag that I hung is already gone that I put in about 4pm yesterday
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If you knead the bag you can get it done in about 10 minutes if you have the patience and are in a hurry to get it in there. I'll usually put it in a skimmer as it's just easier and then once in a while squeeze the sock, wringing it out like a wash cloth and then swishing it around to get more water in and wringing it out again. Depending on how many times and how long I do it each time it's usually gone in a day or two. Once the sock is empty it still can take up to a week for it to show up in a CYA test so save your chems and give it a week before retesting. You also need to refrain from backwashing for that week too or you may be flushing the CYA you just added back out.
    If you needed to vacuum you want to take it out of the skimmer so it's not in the way.
    Solar Blanket, Well Water, Borax Added. 68
