Results 1 to 7 of 7
Thread: Pavers under feet leveled to same grade but ground is not... problem?
    Jul 2014
    SoCal
    9
    Been lurking for a bit and finally posting. Getting ready to install an intex ultra frame pool and have a question. I have my pavers placed and leveled to the same grade using a water level. The ground is not 100% leveled out though. Difference of about 2" in spots. Will this cause a problem or will everything be fine since the pavers and thus the pool frame are level?
    Appreciate all the help and knowledge on this site!
    Mike
    Jun 2013
    Buffalo, NY
    80
    Re: Pavers under feet leveled to same grade but ground is not... problem?
    It will be a problem. There will be an uneven distribution of weight which will push out differently on the legs.
    There was a post not too long ago where a few of the legs were way out of whack and I believe your situation is what caused it.
    If you haven't put up the pool already, take the time to level the center out. You will be very glad you did in the long run. It sucks but is certainly a necessary evil.
    Intex 16 * 48 Ultra
    2650 Intex Sand Filter
    Hayward Thruwall Skimmer
    Hardplumbed in 2014
    TF100 Test Kit
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by frdvschvy View Post
    Mike
    Mike, I just got done doing the same thing. It sucks and not fun at all. I have the SoCal clay soil that isn't fun to dig or level I used DG to level the center out with the pavers that I leveled. Take a look at my build thread in signature. Good luck and it will be worth all the work when your pool is spot on level.
    And Welcome to TFP!
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Casey's Avatar
    SW PA
    10,421
    Don't quit half way through the leveling stage and call it good. Keep going! You will be glad you did! It's tough but worth looking at a nice and level pool without a bumpy, uneven surface under foot.
    The ring where the walls will sit needs to be quite level. The middle is much more forgiving, as long as it is fairly smooth it can wander around a little.
    Once you have the pavers carefully leveled, it isn't too difficult to use a 2x4, either running from paver to paver, or swinging out into the field with a normal carpenters level to keep things stable, to transfer that height to the rest of the area.
    Jul 2014
    SoCal
    9
    Thanks for helping me keep my eyes on the prize (nice level ground)! It gets so tempting to cut corners as I feel like I have been digging for a couple of weeks and the wife is starting to get antsy to move to the next step. I will keep digging and get everything leveled out nicely before laying down the DG and then Gorilla Pad. I am also going with a 2650 GPH pump and SWG right off the bat with hard plumbing. I will get a build thread going after all this digging is done to document. Thanks for the encouragement to take my time and do this right. I am certainly not getting it at home LOL.
    Casey's Avatar
    SW PA
    10,421
    You are doing the right thing! It will be so much easier to vac a smooth surface than craters on the moon! If wifey is so impatient, hand that beauty a shovel!
