Thread: High FC and pH testing
    Jun 2014
    New Jersey
    40
    I am aware the FC levels of greater than 10ppm will affect pH testing. And, one can dilute the pH test sample with distilled water in order to overcome the issue. My question is there any other reliable way to compensate for higher FC and pH testing?
    such as;
    1) Using a scale to adjust for the testing error? That is... if FC levels = XXppm greater than 10ppm, compensate result by X.XpH?
    or
    2) Adding two drops of the R-0007 (sodium thiosulfate) chlorine neutralizer prior to testing pH?
    If I'm way off track (not uncommon for me), please let me know.
    Splash
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit.
    38,520
    Re: High FC and pH testing
    No and no. Sorry. I have never tried the dilution method myself.
    Jun 2014
    New Jersey
    40
    Jason, thanks for the reply. 50/50 sample and distilled water works fine. Just looking to simplify while keeping at higher FC levels. I'm keeping my FC right about 10ppm with my CYA at 60. I have constant leaves dumping into my pool.
    FC at 10 shouldn't be a problem for the Taylor PH test. Between 10 and 15 it only reads a little high, close enough for most use.
    Jun 2014
    New Jersey
    40
    Quote Originally Posted by JasonLion View Post
    And thank you Jason
    Maybe I'll post a comparison of tests if I ever need to SLAM again. I hope I would not need to do that, but it might be informative.
