Thread: Are there any problems with worn marcite that exposes concrete other than cosmetic?
    Jun 2014
    Central Florida
    36
    I just grabbed this image off Google. I have a spot that looks similar, but not as bad.
    I found this much elsewhere "A worn surface can stain more easily, promote algae growth not to mention be rough to the touch."
    Can there be more serious problems?
    22,000 gallon in ground, gunite, Hayward pump 1.5 hp and 36sq DE filter. Pool installation date unknown, at least 10 years. Screened enclosure.
    Re: Are there any problems with worn marcite that exposes concrete other than cosmeti
    You have it just about right. If it is severely worn (much worse than in picture) it will also leak, though only fairly slowly.
    If you can live with the appearance and run at slightly higher than normal FC levels you can often put off resurfacing the pool for years.
    Aug 2010
    Dallas, TX
    4,052
    Like mine used to look. Biggest problem I had was black algae will get in there. Black algae is a real pain to deal with too.
