Thread: Pin hole in liner
    DonW's Avatar
    Jun 2008
    Central IL.
    Pin hole in liner
    Has anybody ever heard of "Fix a Leak"? I don't know if I have a pin hole in my liner or not. At one point on the pool sidewall the ground is damp at 2 locations. It's a brand new pool and I don't want to change the liner, but I don't want frost heave issues in the winter either. I don't have any stones or landscaping down yet so I can see the dampness. I tripped across this: ... _store.htm
    Any thoughts?
    18' x 33' AGP
    16,715 gal.
    200 lb. Sand Filter w/Hayward PowerFlo MATRIX 1.5 H.P. 2 Spd. pump
    Stenner Injection Pump System
    Mar 2007
    Coastalish 'down easter'
    Re: Pin hole in liner
    Hi Don! Welcome to TFP!! If you know the suspected area, squirt some food coloring in there and see where it's being drawn in, where the dye gets sucked in, apply a patch
    This is a quick answer and if you need more info, just ask
    Luv& Luk
