Thread: First test New pool
    Jun 2014
    West Virginia
    16
    First test New pool
    Hello, this is my first pool and my first test on this pool using a AquaCheck test strips. The results are not what what I was hoping...
    PH = 6.2
    Chlorine = 10
    Alkalinity = 30
    Stabilizer = 0
    Now from reading "Pool School" right now I should be concerned with the PH and Chlorine levels? Now reading the paperwork with the test kit it says I need to Add 1.5 LB of Soda Ash to raise PH but im not quite understanding the rest.... The Chlorine is a auto chlorinator and I was told to put it on full so I just turned it half way up. Suggestions?
    Oh my water is crystal clear......
    Location - Northern Panhandle of West Virginia, 24' Round 54" 15,000 Galllon Azor Above Ground, Pentair 1.5hp 22" Sand Dollar, Aqua Pro500 Heat Pump, Hayward In-Line Tablet Chlorinator, Pool Rover Jr., 16 Mil Ultra Clear Pool Solar Cover,
    Re: First test New pool
    Definitely raise the PH first. I suspect it will take way more than 1.5 lbs. I recommend adding 2 lbs, give it an hour to mix in, test the PH and repeat until the PH is at least 7.2.
    One the PH is in range (7.2 to 7.8) check the TA again and adjust TA if needed.
    It seems like you can turn down the chlorinator to lower than half way. Finding the correct spot on the dial often takes a week or two of fine-tuning, and then will change slowly from there.
    Jun 2014
    West Virginia
    16
    Ok, should I raise the Alkalinity first to stabilize PH when I do raise it? OR just raise the PH first?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by SoggyCashew View Post
    Soda ash will raise both pH and TA. "Definitely raise the PH first. I suspect it will take way more than 1.5 lbs. I recommend adding 2 lbs, give it an hour to mix in, test the PH and repeat until the PH is at least 7.2.
    One the PH is in range (7.2 to 7.8) check the TA again and adjust TA if needed."
    Jun 2014
    West Virginia
    16
    Well you guys very helpfull im good now it raised between 7.4 - 7.8 along with my alkalinity. Thank you very much!
    38,361
    I have to jump in and point out that we put very little faith in test results that come from test strips. You would have a much better understanding of the pool with one of the recommended drop-based test kits.
