Thread: Chemicals & possible clog - not sure
    Jul 2014
    Richardson, TX
    2
    Hello.
    I am new to pool maintenance. I had to drain my in ground pool and clean all the algae that was on the walls and refill it. So, upon adding all the chemicals recommended by my pool store, I got it back to it's opening stage I believe. My problem is when I added the Hardness, my pump no longer is working. It sounds like it's just on but I do not see any water rising to the top of the pool pump basket. It was working fine, full force, up until i added the Hardness. Did I clog it by adding that and if so, how do I unclog and get it back to working again? Help!
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: Chemicals & possible clog - not sure
    How did you add the calcium hardness increaser? Did you broadcast, dump it in the skimmer, etc?
    How much hardness increaser did you add?
    Please update your profile and signature so that we can give you specific advice:
    Profile
    Please put the city and state in which you live in your profile. Your climate is important to the advice you receive.
    Signature
    Please put the following information in your signature.
    The size of your pool in gallons
    If your pool is an AG (above ground) or IG (in ground)
    If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    The type of filter you have (sand, DE, cartridge) and, if you know, the brand and model of the filter.
    If you know, please tell us the brand and model of the pump, and mention if is it a two speed or variable speed pump.
    Date of pool build/install, particularly important if less then a year old.
    What kind/model of water test kit you are using
    Other significant accessories or options, such as a spa , SWG, or cleaner
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jul 2014
    Richardson, TX
    2
    I am in Richardson, TX and the temp is 99 degrees here at the highest. I put the Hardness around the pool where the returns were. Not in the skimmers. It called for 16lbs 8 oz according to the instructions I got from the pool company. I put the whole bucket of 15 lbs only. The pump is working now. I went to the pool company and was told to adjust the valves. Got it working and no clogs. Thank goodness.
    My pool is 22,000 gal.. in ground... plaster. The filter, I believe is a Hayward.. DE. The house was built in 1978 and I believe the pool was built then..not sure. My parents own the house now and I think they are the 2nd owners. Again, not sure. I just moved in with them and have taken over the pool maintenance since my father is now 80 and not able to anymore. As far as the test kit, I just take a bottle of the water and have it tested at the pool company. It does have a spa (which we don't heat up and use as a spa) just have it fill and spill over into the pool.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Welcome to FTP! This forum which is run by pool owners sharing their knowledge for free.
    This forum suggests getting your own test kit, learn what you pool needs and only add what it needs so that you are not blindly following pool store advice. Pool stores want you to keep coming to them and buying overprice and sometimes unnecessary magic potions.
    Unfortunately, without accurate test results, we can't give you very much advice when it comes to chemical needs. The great news is that most chemicals you need to keep your pool clean and balanced can be purchased from a grocery store, Wal-Mart, and/or hardware store for a fraction of the price you pay for pool store chemicals.
    1. Buy one of the recommended test kits: http://www.troublefreepool.com/conte...its-comparison
    2. Read pool school so that you know what chemcials you need. http://www.troublefreepool.com/content/1-pool-school
    3. Play with pool math so that you know how to dose your pool: http://www.troublefreepool.com/calc.html
    Enjoy a clean pool all year for a fraction of what you would spend in a pool store.
    Karen
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by Ingrid View Post
    Hello.
    Has it softened up yet?
    I'd try stuffing a garden hose down the skimmer on full blast. And if that didn't budge it, open up the pump strainer basket and stick the hose in that way and seal it with a rag and try blasting it loose that way.
